I would remove 2 strips half way rather than remove 1 completely. small high output motors need to work a lot more so they run hotter. also check your intercooler (below the passenger side headlight if u in a left hand drive car) has proper ventilation you don't want to blow your turbo just yet. other than that im keen to see the results! this is going to be my first mod too also using exact same rc plane materials here we call it solarfilm.
