Old 02-19-2015, 10:40 AM   #121 (permalink)
Daox
Originally Posted by Baltothewolf View Post
Doax, can you make the wires like 3 feet if it's okay? I don't know if it's possible but it would be nice.
I can do that, but it will be a pain to install. As it is with the shorter 12" leads, its kind of a pain to keep the wires from wrapping around the shifter shaft as you install it (screwing it on takes a lot of turns). With that long of leads, it'll be an even bigger pain. I would suggest using short leads, and putting some crimp on connectors on the ends so you can just plug it in once you screw it on. Thats what I'm doing with mine.
