Old 02-19-2015, 12:36 PM   #124 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
I can do that, but it will be a pain to install. As it is with the shorter 12" leads, its kind of a pain to keep the wires from wrapping around the shifter shaft as you install it (screwing it on takes a lot of turns). With that long of leads, it'll be an even bigger pain. I would suggest using short leads, and putting some crimp on connectors on the ends so you can just plug it in once you screw it on. Thats what I'm doing with mine.
I never thought about that, yea I'll just use crimp connectors, thanks! Any idea when you'll be done making it?
