So I got the rear end put in a couple days ago, along with my rear shocks and upper/lower control arms (rear) and holy ****!!! This car woke up!!! I also inconsequentially solved the braking problem. When my buddy and I went to bleed the brakes this thick, green goop came out of the lines (algae? Idk the car sat for a long time). After that, my brakes will lock up at low speeds if I stomp on the pedal, which it would T do before. I'm happier than ever! Things I'll be doing later this month/early next month.
Subframe connectors.
P/S pump and smog pump replacement.
Koni adjustable front shocks.
Replace speedometer cable.
Replace speedometer gear.
Transmission fluid and filter change.
Oil fluid and filter change.
Install rims (look brand new with no noticeable curb rash).
