The nicest Metro I've ever seen on the streets was metallic blue with those wheels, probably the same as the 'sister car'.
How many conversions have you done, over how many years? What performance would you expect with a 68hp/50Kw 10,000rpm single speed AC motor?
68HP is about what a stock gasoline powered Metro comes with, and I would think that single speed would be a bit of a problem. The torque would probably be more than the ICE motor, but I would want a transmission. I run the factory 5 speed in this rig, and this is a 70Kw set up.
