Old 02-22-2015, 04:25 PM   #4 (permalink)
gone-ot
...beats walking...
I know NOTHING about that CA device, but a SHUNT is a physical, electronic, very-low RESISTANCE device that covers the CURRENT passing thru it into a specific VOLTAGE signal.
The ratio, or scaling coefficient, "X", is simply:
VOLTS(out) = X/AMPS(in)
Ask the selling vendor what shunt(s) the CA is designed to work with...it will probably be a number like "millivolts-per-amp"...the scaling coefficient, X, above.
