On the pusher Front so to speak,
At present making mounts to use an Etech 5kw motor to mount as a 5th wheel drive on a Smart car, to do town/ traffic running, and lift from the ground for motorway, reverse and maneuvering , at first to trial, and then maybe connect up to steering in some way, mechanical rod, or servo driven.
This would leave all the ic drive as original, whereas a Toyota Q211 unit (MGR) necessitates removal of the ic if used in engine space.
