Old 02-26-2015, 07:09 PM   #21 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by huntersirg View Post
I've been doing a lot of reading on the foamie teardrop trailers with this cheap fiberglass alternative.
Seems they are making a lightweight trailer bodies just by using blue or pink bigbox store insulation foam, then covering it in this order titebond II/drop cloth canvas/gripper primer/exterior porch paint and claiming a very strong super lightweight waterproof shell.
Might be a good alternative to chloroplast for boattails and such as you can gorilla glue the foam to your desired shape then just wrap it with the canvas.
Do you have a link? I need to build a lightweight removable boattail.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
