Old 02-27-2015, 10:21 AM   #41 (permalink)
McDesign
Accord interior mirrors
I've been using this set-up for a couple years now, and it works fine. I drilled a 7/8" hole in the little coin tray left of the steering wheel, and used a threaded and an unthreaded 1/2" PVC (gray electrical, not plumbing) sweep.
Used box nuts above and below the tray bottom. I couldn't get it as tight as I liked, so I built up fillets above and below with J&B Weld.
Sprayed it all black. Mirror is made to clamp onto a 1" stalk, so perfect.
I actually sawed off the side view mirror protrusions from the removeable triangles at the front of the windows, and fiberglassed them flat before normal bodywork and paint.
The rearview is a nice glass curved unit from EBay; cames from Israel, IIRC - writing on it is in German.
ID:	17096   Click image for larger version
ID:	17097   Click image for larger version
The Following 3 Users Say Thank You to McDesign For This Useful Post:
aerohead (02-28-2015), BamZipPow (02-27-2015), mikeyjd (03-06-2015)
