Old 02-27-2015, 10:21 AM   #41 (permalink)
Accord interior mirrors
I've been using this set-up for a couple years now, and it works fine. I drilled a 7/8" hole in the little coin tray left of the steering wheel, and used a threaded and an unthreaded 1/2" PVC (gray electrical, not plumbing) sweep.
Used box nuts above and below the tray bottom. I couldn't get it as tight as I liked, so I built up fillets above and below with J&B Weld.
Sprayed it all black. Mirror is made to clamp onto a 1" stalk, so perfect.
I actually sawed off the side view mirror protrusions from the removeable triangles at the front of the windows, and fiberglassed them flat before normal bodywork and paint.
The rearview is a nice glass curved unit from EBay; cames from Israel, IIRC - writing on it is in German.
ID:	17096   Click image for larger version
ID:	17097   Click image for larger version
The Following 3 Users Say Thank You to McDesign For This Useful Post:
aerohead (02-28-2015), BamZipPow (02-27-2015), mikeyjd (03-06-2015)
Old 03-05-2015, 02:12 PM   #42 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Modded one of the mirrors fer better adjustment on shallow windshields. Not sure how well it will stay in place over the long run.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (03-05-2015)
Old 03-06-2015, 07:47 PM   #43 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Installed the modified mirror in the wife's Cadillac El Dorado. The shallow windshield angle prevented the unmodified blind spot mirror from adjusting fer the shallow angle. No problem now!
The blind spot mirror is now on the same plane as the stock OEM exterior mirror so there shouldn't be that much of an adjustment from wide to narrow.
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (03-07-2015), nemo (03-07-2015)
Old 03-06-2015, 08:03 PM   #44 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
I have discovered that if the blind spot mirror is mounted slightly higher than the OEM mirror...any glare you normally git in the OEM mirrors are usually minimized in the blind spot mirror because of the different viewing angle.
Old 03-07-2015, 02:12 AM   #45 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Looks like Pep Boys sells the same mirror fer about $4 more.
http://www.pepboys.com/product/details/224659/01036
Old 03-07-2015, 09:12 AM   #46 (permalink)
90 day: 19.36 mpg (US)
Mirrors for a vehicle with trailer need a convergence point at/before 200'.
Ck state law.
Also, any device mounted on windshield interior is pretty much a no go if intrudes 6" from frame AND within wiper sweep of glass as seem from drivers position. (One or the other will apply).
The Following 2 Users Say Thank You to slowmover For This Useful Post:
aerohead (03-07-2015), BamZipPow (03-07-2015)
