Old 02-28-2015, 02:03 PM   #21 (permalink)
freebeard
Anyways thanks for the input freebeard. Man i need a shop!
Me, too. There are seams in the rubber sheet? Where are they. I could see rubber cement to hold the rubber sheet against the stringers, but I suspect there would be some minimum overlap needed to resist shear.
Four posts in less than an hour? If no-one has replied you can just edit the initial post.
Tying everything together in flat black would help visually. It sounds like a job for 6-8 coats of Plastidip S. It would 'similarize' various materials and probably match the rubber sheet on the cap.
