Old 02-28-2015, 04:17 PM   #76 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by bluesteel93 View Post
Looking good man! Did you check the wear pattern on the ring and pinion? It may be shimmed improperly causing the noise on deceleration.
Yea when my buddy and I had it apart it looked like it was dead center in the middle of the ring gear. Also I have a feeling if it had something to do with the rear end, it wouldn't only do it in OD . I could be wrong though. There isn't a lot of info on AOD builds as everyone goes T5/T56.
