Old 02-28-2015, 05:43 PM   #80 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by The_Jed View Post
"Since getting this rear end I noticed there is a very loud growl when decelerating in OVERDRIVE, AND ONLY OVERDRIVE above 2100rpm. I have no idea what's causing it. I drove the car this rear end came out of, and it was whisper quiet in all gears at all speeds (but it was a 5-speed)."
Double check the driveshaft flange bolts, they may have backed out. The bolts on the flange of my old blue Lincoln worked loose and the symptoms of that were similar to what you're describing.
Alright I'll check them when I get home. We put lock tight on the bolts, and it sat for like 4 hours, but who knows.
