Old 03-02-2015, 07:47 PM   #30 (permalink)
user removed
Animated Engines - Atkinson
Although it may seem totally different the atkinson cycle engines have higher static compression while actual compression is somewhat controlled by camshaft phasing. Combined with canshaft overlap control you can achieve higher efficiencies at lower throttle positions with higher effective compression and lower pumping losses.
The original atkinson patent was developed to circumvent ottos 4 cycle patents almost 150 years ago.
regards
mech
aerohead (04-09-2015)
