Looks good! Nice idea on the spacers. Nice up close shot of the fog covers. Fitment of those is ON POINT Mr. Plasma Cutter
Any plans to lower the car? Front lip/dam? Man, your paint looks flawless!
You are running a 50-state ECU/O2 set up correct? Im sorry if I've already asked. I'm thinking the EGR clean up is really going to help you a lot. Also, have you ran any seafoam though the fuel tank yet? Maybe run that, then change the fuel filter? Then maybe a new fuel pump sock also? Pump is easy to get to and swap that out. Perhaps try running some 0w20 oil? What's the plugs gap? Compression test? What psi in your new tires? Feel like you have some untapped mpg in there!
what are the temps where your at?
Sorry for all the questions
