Old 03-03-2015, 05:58 PM   #18 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by mikeyjd View Post
I was being sharkastic.. A grill block will increase temps which can be an ok thing unless you block to much and overheat.
Ultraguage is a great investment. You won't regret it.
FWIW I own an Ultraguage and a ScanGuage II and much prefer the ScanGuage. The control buttons are on front and I didn't have to buy a seperate mount for the ScanGuage. I find the trip feature useful allowing me to easily toggle between current, today, yesterday and tank mpg and back to my guages. I monitor temp, intake air temp, instant mpg and gallons per hour. Just MHO.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
aerohead (03-03-2015)
