This winter's toll, so far:
- several chain links rusted up, several times
- broken rear brake cable -- corrosion at the crimped-on lead thinger at the handle end
- broken rear derailleur cable -- corrosion
Fortunately the bulging rear sidewall hasn't let go yet, because changing a tire in the winter is a messy inconvenience. I'm betting it'll make it to spring if it's made it this far!
