Old 03-06-2015, 10:47 AM   #163 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by foxgrockefeller View Post
Just want to reduce intake losses as you say you have zero losses. At some point I'm going to swap to D15z1 I think.
I had some great results with my D15Z1 in my Del Sol.
Here's a pic of it when i did some N/A testing after I painted it.
Neptune screen shot.
This is a pic of the Del Sol before the D15 with a D16Z6 turbo and modified pistons for lean burn running Neptune with a HY35 Holset turbo. I learned a ton with this setup.
My first Civic the Black one with my first attempt building a lean burn system and my sons car the White one running a turbo D15 with lean burn.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
mpgmike (04-17-2022)
