Old 07-23-2008, 11:54 PM   #78 (permalink)
ROFL Box
It is a laughing matter
ROFL Box's Avatar
The ROFL Box - '05 Scion xB
90 day: 46.85 mpg (US)
they are two tenths of an inch SMALLER in total diameter from stock, and a full inch wider... not to mention a total of 3 lbs HEAVIER than stock... they should actually be hurting me
Mind you im running Nitto Neogens, which have a very odd tread pattern, and dont have a lot of rubber that actually contacts the road...
yeah, the speedo needle is off, but the tach is dead on...
and just a little FYI for you 1nz-fe drivers... try to keep it under 3k RPMs whenever you can, at 3100 rpms the VVTI sensors react and the computer advances the timing, opens the valves more, and sends ore fuel
2005 Scion xB - From and made of parts unknown
