07-22-2008, 10:11 PM
#71 (permalink)
Box Dreamer
Man, Congratulation!! It is not an easy number!! and you got a good deal on gas station, too!! My gas station is still $4.31/g. I will work harder for this tank. I hope I can break 40. I start EOC today in town when I am alone. Feeling good on brake, but the steering is harder. Hey, how to resume the motor more smoothly? I use 5th gear and release the clutch slowly, still shake the car....
07-23-2008, 12:20 AM
#72 (permalink)
Boxy is Sexy
Yeah gas went down 20 cents, I have no idea why. But I was very surprised that I still had another gallon in the tank. EOC with automatic is easy, and I mainly use it for waiting at RR crossings.
I don't have any aero mods either, so much potential, but driving is the main "mod" of success! Ahh, the tailgaters.
07-23-2008, 03:11 PM
#73 (permalink)
Box Dreamer
I am doing very good this tank. Already have 200miles but consumes only 3/8 tanks. hehehe.... sure, I can break 40mpg. I tried few more miles EOC before going to freeway. Feels good and have better control in restarting the engine by clutch. However, still don't feel safe to use this technique on a busy freeway.
07-23-2008, 04:34 PM
#74 (permalink)
Boxy is Sexy
EOC is almost useless around here because whenever a hill goes down it comes right back up again. Try to get 240 miles at the halfway mark!
07-23-2008, 04:46 PM
#75 (permalink)
Box Dreamer
You are genuine!!  Without scangauge and still get this good achievement is very hard. What is your average speed? Do you drive freeway a lot in last tank?
07-23-2008, 08:23 PM
#76 (permalink)
It is a laughing matter
Ok, here is a little video... I was on the highway playing around coming home from a friends house the other day and you all had asked about my gear ratio's with the bigger wheels...
Well, My GPS (when I started this) was at 56mph... and i let it run down to 50 (before I shut the car off to drive down my exit and then downhill to my apartment...)
Have at it kids
2005 Scion xB - From and made of parts unknown
07-23-2008, 09:18 PM
#77 (permalink)
Box Dreamer
What a nice mod on the speedometer!! I believe your bigger tires help you a lot on mpg
07-23-2008, 11:54 PM
#78 (permalink)
they are two tenths of an inch SMALLER in total diameter from stock, and a full inch wider... not to mention a total of 3 lbs HEAVIER than stock... they should actually be hurting me
Mind you im running Nitto Neogens, which have a very odd tread pattern, and dont have a lot of rubber that actually contacts the road...
yeah, the speedo needle is off, but the tach is dead on...
and just a little FYI for you 1nz-fe drivers... try to keep it under 3k RPMs whenever you can, at 3100 rpms the VVTI sensors react and the computer advances the timing, opens the valves more, and sends ore fuel
07-24-2008, 12:00 AM
#79 (permalink)
Box Dreamer
That is a good information. I never know 300rpm is the sweet point. So, you shift every 2900 or 3000rpm? I know you can drive much faster than shifting below 2000rpm.
07-24-2008, 12:04 AM
#80 (permalink)
i shift around 2500, going up hill ill shift sooner, going down ill skip gears (normally going 1-2-4-5) Des moines is rather hilly and whatnot...
