Originally Posted by thingstodo
I think I had the 'erase before programming' checkbox checked .. but I'll do the explicit erase, then reprogram. That's step 1.
I'll report back tomorrow.
Step 1
The log file is below copied from MPLAB IPE v2.30
My comments begin with //
Connecting to MPLAB PICkit 3...
Firmware Suite Version.....01.32.09 *
Firmware type..............dsPIC30F
Target voltage detected
Target device dsPIC30F4011 found.
Device ID Revision = 1004
// press the button labeled Blank Check
2015-03-07T12:28:29-0600- Blank checking...
Blank Checking...
program memory
Address: 0 Expected Value: ffffff Received Value: 40100
Blank check complete, device is not blank.
2015-03-07T12:28:31-0600- Blank check failed
// so there IS something programmed in the dsPIC
// so erase it and start again - press Erase button
2015-03-07T12:28:41-0600- Erasing...
Erasing...
Erase successful
2015-03-07T12:28:43-0600- Erase device complete
// load in ACControllerProject.hex file
2015-03-07T12:29:37-0600- Loading hex file. Please wait...
Loading code from C:\Users\lulcm\Downloads\ACControllerProject.hex.. .
2015-03-07T12:29:38-0600- Hex file loaded successfully.
// Press Program button
2015-03-07T12:29:44-0600- Programming...
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x2fff
configuration memory
Device Erased...
// I thought I had that erase before programming box checked ..
Programming...
Programming/Verify complete
2015-03-07T12:29:54-0600- Programming complete
Pass Count: 1
// looks like it worked. Verify it.
2015-03-07T12:32:26-0600- Verifying...
Verifying...
User Id Memory
Address: 8005c2 Expected Value: ffff Received Value: ffffff
Verify failed
2015-03-07T12:32:41-0600- Verify failed
// OK - the program does not verify after the program/verify ran .. ?
// Erase again, repeat the process
2015-03-07T12:33:04-0600- Erasing...
Erasing...
Erase successful
2015-03-07T12:33:08-0600- Erase device complete
// This time we blank check before programming using the Blank Check button
2015-03-07T12:33:58-0600- Blank checking...
Blank Checking...
Blank check complete, device is blank.
2015-03-07T12:34:06-0600- Device is blank
// Excellent - it's blank
// Now program it
2015-03-07T12:34:48-0600- Programming...
Device Erased...
// Oh - should have removed the erase before programming box
Programming...
2015-03-07T12:34:57-0600- Programming complete
Pass Count: 2
// For the second time, programming/verify is complete and has passed
// and NOT failed
// Now to verify it
2015-03-07T12:36:11-0600- Verifying...
Verifying...
User Id Memory
Verify failed
2015-03-07T12:36:24-0600- Verify failed
Not sure if this value is important - not all parts of the chip were programmed.
Program memory appears to be 0x0 - 0x7FFF
Not sure what is at address 0x8005C2 but I'm hesitant to mess with the
PICkit 3 programming setup.
Serial cable 1 still gives me gibberish on the screen at 115K
and still echoes back everything at 9600 baud
Serial cable 2 does nothing. I suspect that I pulled out the pin for tx or rx
when I was soldering. I'll rebuild that with another 3 pin header
If that doesn't work - off to step 2. Install 8.83
