Old 03-08-2015, 07:33 PM   #24 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Testing today. Got much different pressure readings. With regulator vacuum hose off and pinched. Car not running. Not warm. I primed the pump and got 10-20psi, when 38-46psi is the spec. Two weeks ago, this test showed 42psi repeatedly.
So then I reattach the vacuum line. The FSM says pressure should climb slightly, but it didn't. However, two or three priming cycles with the key and it climbs close to the normal range.
Also unlike two weeks ago, the pressure quickly drops off, if I get it even close to normal, whether the vacuum line for the regulator is connected or not.
What the hell?
