Originally Posted by Old Mechanic
It could be a bad fuel pump, odds are bad regulator, replace and retest. Plug check?
regards
mech
I ran the test again just now, and now I get no fuel pressure at all in the first test. Zero. I can hear the pump prime. Could a failing pump create the symptoms I have seen? too much fuel causing trim to get leaner, then too little fuel causing a stall?
