Old 03-08-2015, 11:52 PM   #1 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Question Air intake restriction, manifold vacuum, fuel flow
Could a more restrictive than OEM air intake, such as my current WAI, increase fuel flow by increasing intake manifold vacuum? A significant manifold vacuum increase could pull more fuel through the injectors, no? Would this then confuse the ECU which would know about the added fuel from the O2 sensor and respond by cutting fuel trim? The result could be very unstable idle and really erratic fuel trims changes, no? I could read the MAP sensor data with my scantool to see if the WAI is even increasing vacuum, no?
I am a journeyman/novice mechanic at best ... what am I not understanding about these systems?
