Yeah just double check to make sure that a screw driver or your house key can't start the car too.
The vent fins don't break it's the vertical alignment mechanism that brakes so you have to tilt each fin up and down individually.
I would also check for oil leaks under the distributor onto the block.
My car has a salvage title and 300k miles, the condition of the vehicle is a far greater factor than mileage
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
