Old 03-13-2015, 03:17 AM   #72 (permalink)
oil pan 4
Originally Posted by redyaris View Post
Step one if you deside to go to court is get "disclosure" from the crown prosecutors office. Then see what he has as evidence. study the law he used, then look up precedents if there are any... not likely... the first hearing will be used to see if you will plead guilty if they drop the fine in half. then you will work out a trial date. At trial you should be ready to present your case "on the evidence".
What is most likely is that the cop will not show up and the crown will withdraw the charges at the very last moment...
I am not a lawer but have defended myself in court... successfully.
...should have read the whole thing first...
That's how it works here too.
Your best bet at beating a ticket is for the cop to not show.
