03-15-2015, 06:24 PM
#363 (permalink)
Changfa diesel + Suzuki
Centurion - '74 FIAT X1/9 Centurion Full Race DNA Last 3: 143.5 mpg (US)
Originally Posted by nemo
When I had my Triumph I had an issue with leaking from the hydraulic clutch components. Several rebuilds problem continued. Replaced slave cylinder and switched to silicone fluid never had another problem. Internet has a lot discussion on using silicone vs Castrol GT-LMA. May want to research it. Just my 2 cents and YMMV
nemo,
Thanks for the tip! I'll likely do exactly as you did. Just got all the electrics straightened out (again) so the clutch master is on deck next.
~CrazyJerry
