Awesome, can you take a picture of the cylinder head numbers directly next to the coolant outlet on the head. On my y5 the numbers are upside down which has a few of the other moderators on h-t confused but I believe the y5 heads were given this designation to seperate them as solid roller heads.
There should also be a year stamped on the head next to the dip stick to indicate the year the head was made
Be sure to clean that intake manifold from stem to stern to clear out that egr passage way
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
