Still grooving on the quality of your work.
I absolutely marvel at your all-up curb weight. 2026 lbs! WOW. There was a time when that was the kind of weight you might hope for in a glider, before you started screwing in the motor, tranny and batteries - never mind the interior.
With such a featherweight chassis to start from, I wonder what kind of steady-state range improvement you could achieve with a removable kammback, or other aero improvements. I saw you've done some with a grille block but don't know about any other mods you may have done. If anybody around here could put together a trick-looking kamm, you're the guy.
Looking forward to more.
