Booh, that's cold... we've seen minus 8 at lowest this winter; had to scrape some ice even last week, but always close to 0°C.
Green Oil would make an even bigger difference at -20°C.
I measure my fuel use over the first 10 km from a cold start and saw up to 300 cc 'over target' last year at the few frosty mornings.
This year nothing below 200 cc 'over'...
I guess it takes about a third of the cold start penalty away.
I've had only one cold induced 12V start; at -14°C two years ago. It being that cold is really exceptional here.
I did not test whether AutoStop worked with ventilation OFF then - wasn't into that at the time.
Engine coolant temp needs to be 48°C or higher anyway. The blue light goes off at 51°C, so it is possible to have AutoStop while having the Cold Engine indication on - just.
