Originally Posted by bandit86
First off the trailer will need a 3 inch lift kit to get the bottom out of the air passing under the truck.
Um, aren't we stepping over a dollar to pick up a dime here? Moving your already high roofline another 3 inches up will probably hurt you more than you gain by matching the bottom of your trailer to your truck.
I wouldn't do this unless you had some other reason for raising it, like a need for more ground clearance.
