Old 03-24-2015, 11:33 AM   #193 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by figit090 View Post
awesome thanks for sharing, that's pretty neat. Is the toluene used to increase MPG in your system?
Yes the Toluene is use as a fuel source to improve my fuel mileage.
Here's a MSDS sheet on PPG Omni MS 251 clean up thinner.
http://secure.terrys.net/%5CMSDS%5COMNI%5CMS251.PDF
The PPG Omni MS 251 is the clean up thinner that I sell to all my customers shop's that is used in their gun cleaning machines and part of the final wash in the gun cleaning process. After a month or so they dump out the solvent into a 5 gallon and then run it through their recycler along with paint that's discarded from a job left overs. The paint recyclers also separates the solvent that is in the clear,color, and primer etc.
So there are a few different solvent's in the waste paint solvent that I'm using.
The main ones are Toluene at around 69% then Methyl Alcohol 29% and the rest are Naphtha etc.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
Ardent (03-24-2015)
