Thread: VX engine swap
Old 03-24-2015, 06:18 PM   #2 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I have not done it. But I have mucked about with my 98 DX a lot, research and under the car. The engine and transmission mounts are the same I think, certainly the transmission is. You'd need the wire harness for the engine and the ECU, which you have. But even the VSS works in exactly the same way. Your existing 96 speedo/VSS would work with the VX transmission easily... simple plug & play.
EDIT: wait... I just noticed you said the 96 has an auto trans... that's obviously more complicated... shifter location and type... gets to be a PITA.
