Old 03-26-2015, 06:49 AM   #1 (permalink)
Joggernot
Joggernot's Avatar
New Rear Bearings
Noise started coming from the rear of the car. Checked the tires for uneven wear, and settled on the drivers side rear bearing going bad. Was glad I had my local mechanic replace the hub and bearing on both sides because he had to drill out a couple bolts in the process.
End result, I have to recalibrate my coasting distances! I started arriving at the lights/stops way too fast, and need to start coasting a lot farther from them. Guess the bearing was going silently bad for a while until it became noticeable. I'm really hoping this helps the city driving I've been doing lately.
The Following 2 Users Say Thank You to Joggernot For This Useful Post:
Gasoline Fumes (03-26-2015), pgfpro (03-26-2015)
