Old 03-27-2015, 05:52 PM   #17 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Originally Posted by Sven7 View Post
If you want to keep your new tubes you can buy an adapter to bridge the gap between the Devil's Valve* (presta) to normal Schraeder. It's just a little brass cylinder you screw onto the end of the presta. Better than presta, worse than Schraeder, and available for about $0.50 from your LBS. It'll work with your pump, though!
*Also known as, "$&%# these stupid twisty valves!"
How do you like the new tires? Do they roll better?
Yep have found out about the valve adapters. Thanks for the info though!
Re the tyres i have no idea-i went to the pub this evening instead
With luck i should be able to test them tomorrow during the day and get a ba k to back average mph on the turbo trainer.
Will report back!
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
