Originally Posted by Chrysler kid
... In general all parts cone from the same batch of 3rd party vendors. I manage an autozone store and can tell you to shop where the good car people are, not by parts.
Both regulators from Autozone came from the same supplier, but the O'Reilly's was a different aftermarket brand. I agree with that recommendation of going where the people are.
If the next one fails I would try oem honda. I also question the strength of your fuel pump. A regulator is a simple device you may have contaminants getting past the filter
Yeah, it's true, but the fuel pressure was strong in the normal when tested. It could be fading, but it didn't reveal itself in the test. When I did the regulator again, I changed the fuel filter because I hadn't in several years and I had that part of the system partly dismantled already, so it was as easy as it'll ever get. Now, if I could finish with this oil pan already I'd be stylin' in my 98 Civic inertia-gasoline, plug-in hybrid.
