Got the arms cut and tensioned...
Installed a new tire as the previous tire had about 25,000 mile on it over the past year and a half and had started to wear more on the left side of the tire.
Hit all the zerks with grease so everything will be super smooth with new grease.
The lazy Susan belly pan cover will be approximately a diameter of 34.5" which should give about 1.5" fer clearance.
