Old 03-28-2015, 05:25 PM   #2 (permalink)
War_Wagon
5 Gears of Fury
War_Wagon's Avatar
Spunky - '90 Honda Civic CX
90 day: 35.56 mpg (US)
I'd take the VIN from the ad, and call the service dept of your local Honda dealership. Ask them if there has ever been a warranty replacement of the traction battery on that car, they should tell you. It will give you a bit more info on whether or not it's been replaced. Odds are if it has been, it was done at a Honda dealer, and probably under warranty. If you go look at the car, make sure the IMA light on the dash comes on when you cycle the ignition key. So in other words, when you first turn the key on before you start the car, look for the IMA light, it should come on. If it doesn't, then someone may have disconnected the warning light.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
The Following User Says Thank You to War_Wagon For This Useful Post:
AbramWagner (03-28-2015)
