Originally Posted by whokilledthejams
Older SAABs had a freewheeling feature, because they came with two-stroke engines (I forget precisely why, but you can't engine brake with a two-stroke). They even carried it over into some of the early four-stroke 96's
commonly called a
sprag... the 2 speed Lenco race transmission i had apart uses them, it looked remarkably like a bicycle freewheel, albiet on steroids. You can get sprags for different torque ratings, maybe even salvage one from and automatic transmission torque converter.
As for those decrying the frontal area of a VW front beam: those cars are really, really small compared to anything modern...I wouldn't be surprised to find that it's only 50" or so...
I have removed as much as 4" from a VW beam, minus 6" has been done, the baja guys add width. Neither is a problem for any half-decent fabricator. I see no reason you couldn't get any track width you wanted.
I used to work with a real good welder/fabricator, who tinkered with buggys and sandrails. Notoriously frugal, kinda lazy, inovative and avid recycler by neccesity, and driven by outstanding craftsmenship, Frank always amazes me. With a need, a clean sheet of paper and an imagination, almost anything is possible.
