So as I think about how I can git a lower profile fer the rear part of the main rails to gain maximum clearance from the bottom panel, I believe I can cut the vertical "fins" off just past the vertical supports. I should be able to bolt in a horizontal flat bar to keep the spacing and support in the rear the same as the front.
Dark Aero-The world's first aerodynamic single wheel boat tail!
