Finished my Low Pressure Turbo to High Pressure Turbo Charge Pipe today. This is the 3rd one I built and I'm happy with this one for now.
![](http://i147.photobucket.com/albums/r312/rrussell_photo/IMG_0900_zpszxn6qvkn.jpg)
I decided to run my oil feed line and oil return line down the same path with the charge pipe. This keeps everything much cleaner and away from the exhaust pipe and drive-shaft.
I did some pressure testing also, from 10 psi to 30 psi to make sure it didn't leak or blow. Had my ear protection on also just in case.
Also the ladder is not part of the charge pipe. Its just a great place to put the charge pipe while I work on some other things.lol
