Originally Posted by mazdamx640
Well I got my fist tank in and it returned 33 mpgs that's not bad considering the rear tires only had 11 and 20. So time to start ecomodding I removed the antenna and license plate bracket. I changed the oil to mobile 1 5w30 and aired the to 51 psi. The next problem I need to take car of is the thermostat because the hottest it ever gets is 175 and I can't find a replacement over 185 degrees
33 mpg with 2 near flat tires is a great start!
Be careful airing up the tires if they have dry rot cracks. I learned a lesson the hard way... 58 psi in 44 max psi tires with dry rot equalled tread seperation while driving
If you can't find a higher temp thermostat, block off your grill to raise the coolant temperatures
![Thumbs up](/forum/images/smilies/grinning-smiley-003.gif)
go full block and trim some out if your coolant temps need it.
Fyi, Saturns seem to like warm air, so a WAI should help based on some other results in the past. Use the search bar to find out the exact parameters.
