...and we have a quick 35" diameter cardboard cover to make a Coroplast cover from.
Front view...
Cross section view...
Side view...
Rear view...
After installing this cover, there are some clearance issues that need to be addressed. I need to cut the diameter to 34" and build up the bottom to match the cover as the cover is lower than the current bottom. I only need to match the bottom profile when the wheel is straight forward.
