Old 03-30-2015, 11:34 PM   #253 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Have you experienced this?
Finished the oil pan gasket replacement, part of a project to eliminate a last fluid leak so I can install a more extensive front-end undertray. The old gasket was in such bad shape it took hours to scrape the brittle and cracking old bits off the oilpan.
But I still have the oil leak.
Even before doing this job, I suspected the front main seal too but I was unable to tell for sure. The oilpan seemed easier, and it has never been replaced. But there is new oil on the cardboard I left under the car after my test drive this evening, three to five drops I would guess. Maybe it is residual oil dropping off the engine after it warmed up. But all the drops are in one small spot right under the front main seal behind the crank pulley.
I gotta do the front main seal too, don't I?
