For those of us not up to speed on Honda engine management, why do you need the controller? If the wide band sensor is already being used as such there will already be a controller in there somewhere.
You just need to tap into the signal with a volt meter. The meter or the circuit, i.e. voltage divider, it is connected to should have a high impedance or resistance to avoid altering the signal you are reading but that's all.
