Old 09-21-2014, 12:05 PM   #1 (permalink)
Wideband controller for monitoring D15Z1 lean burn
I have a D15Z1 and am using the L1H1 sensor and P07 ECU.
Since there are a bunch of wideband controllers out there that use the L1H1 sensor, I'd like to hook one up so I can use the gauge for monitoring AFR.
I just want to make sure tapping into the needed wires for the wideband controller wont screw with the readings that the ECU receives.
Also, are there any wideband controllers & gauges that can read leaner than 20:1?
EG Civic CX with D15Z1 swap
Old 09-22-2014, 01:15 AM   #2 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
bump for great questions that need answers.
2000 Insight MT 106K Citrus A/C
Old 11-18-2014, 08:20 PM   #3 (permalink)
bluesteel93's Avatar
Turtle - '94 Honda Civic VX
90 day: 48.37 mpg (US)
SVO - '86 Ford Mustang SVO
Team Turbocharged!
90 day: 22.03 mpg (US)
I'm going to bump this again because I've been wondering this myself lately and cant seem to find and information on the subject...
Old 11-19-2014, 02:20 AM   #4 (permalink)
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
From my understanding no one has risked their $150 oxygen sensor to tap for a wideband gauge. Please feel free to be the first and let us know how,it works for youl lol
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
Old 04-02-2015, 12:44 PM   #5 (permalink)
WD40's Avatar
Gen-1 Insights
re: I just want to make sure tapping into the needed wires for the wideband controller wont screw with the readings that the ECU receives.
When my VX was in the shop recently being worked on by a former Honda mechanic and civic modder, I asked him that question specifically and he said it would not interfere.
He is currently into playing with 16:1 lean burn on an older turbo Mitsubishi Mirage HB.
I will tap into mine whenever I can afford an appropriate monitor gauge.
Old 04-02-2015, 06:10 PM   #6 (permalink)
For those of us not up to speed on Honda engine management, why do you need the controller? If the wide band sensor is already being used as such there will already be a controller in there somewhere.
You just need to tap into the signal with a volt meter. The meter or the circuit, i.e. voltage divider, it is connected to should have a high impedance or resistance to avoid altering the signal you are reading but that's all.
