Old 04-02-2015, 08:35 PM   #27 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Originally Posted by Grant-53 View Post
1) Chain is cleaned and oiled
2) Check to see that front derailleur is 5mm above large chain ring
3) Shift to lower chain ring and adjust limit screw to move cage over inner ring
4) Shift to upper chain ring and adjust limit screw to move cage over outer ring
5) Adjust cable tension to suit.
I use moly disulfide CV joint grease to lube cables. If you are concerned about health warnings, wear gloves.
Our local library has several books on mountain bike repair.
Unless someone has put a hex on it, a machine is not out to get you
What tyre pressure are you running?
Pretty much what i'm planning to do
Running 50psi
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
