Old 04-06-2015, 11:14 AM   #298 (permalink)
echo-francis
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
Originally Posted by jcp123 View Post
I have been looking over your pictures. I want to start on some belly pans for my Echo but the contours down there are frustrating. Would you mind showing some more pictures of what you did and where you fastened them/what you fastened them with? Maybe some insight on how you designed your belly work? The rear belly pan you have is interesting, what did you use to reinforce it? Do you have anything at the front, where the torsion bar is, to block air from getting inside it? Thanks!
- James
for my front belly and rear belly pan i used this
Rawlplug Nylon Plasterboard Self Drill Fixings & Screws (Pack of 25)
i screwed this in the bumper and in the oem belly pan. here some pictures of my belly pans
old belly pan
for my middle belly pan i used this Carbon Steel Toggle Bolt, Zinc Plated Finish, Mushroom Head, Combination Phillips Slotted Drive, Meets ASTM B633, Right Hand Threads, Inch | AmazonSupply.com in the holes of the frame to make a aluminium frame and i did the belly pan on the frame.
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
The Following 6 Users Say Thank You to echo-francis For This Useful Post:
BabyDiesel (05-13-2015), California98Civic (04-10-2015), Daox (04-09-2015), HyperMileQC (04-26-2015), j12piprius (04-06-2015), mikeyjd (04-06-2015)
