12-11-2014, 10:04 PM
#291 (permalink)
Liberty Lover
Originally Posted by echo-francis
its sure that if it sounds too loud I will not do it but my straight pipe should be 1 or 1.1/4 pipe diameter and I want to try if that make a difference in the sound. if not I will go with a glass pack like you did
What did you end up doing in place of the muffler and how do you like it?
12-11-2014, 11:49 PM
#292 (permalink)
40-60-40 MPH P&G
I ended up geting this¸
it is louder then stock but very acceptable
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
12-12-2014, 12:16 AM
#293 (permalink)
Liberty Lover
What kind did you get, and did you attach it yourself?
12-12-2014, 12:35 AM
#294 (permalink)
40-60-40 MPH P&G
i got this http://www.summitracing.com/int/part...015s/overview/
and I welded it my self
MPG=1 TIME=0
The Following User Says Thank You to echo-francis For This Useful Post:
12-12-2014, 07:54 AM
#295 (permalink)
Not bad for a machine
Nice! any idea the MPG jump with that?
12-12-2014, 10:06 AM
#296 (permalink)
40-60-40 MPH P&G
i didn't notice any mpg changes but it removed 7 lbs and it allowed the construction of a simpler rear belly pan and that was the goal
MPG=1 TIME=0
04-04-2015, 06:52 PM
#297 (permalink)
Just cruisin’ along
I have been looking over your pictures. I want to start on some belly pans for my Echo but the contours down there are frustrating. Would you mind showing some more pictures of what you did and where you fastened them/what you fastened them with? Maybe some insight on how you designed your belly work? The rear belly pan you have is interesting, what did you use to reinforce it? Do you have anything at the front, where the torsion bar is, to block air from getting inside it? Thanks!
- James
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
04-06-2015, 10:14 AM
#298 (permalink)
40-60-40 MPH P&G
MPG=1 TIME=0
The Following 6 Users Say Thank You to echo-francis For This Useful Post:
04-06-2015, 12:49 PM
#299 (permalink)
Just cruisin’ along
Nice, that gives me a lot to look at. In your opinion, how necessary is having the additional support framework?
04-09-2015, 06:46 PM
#300 (permalink)
40-60-40 MPH P&G
for the middle belly pan, i dont see any way to do it without adding a frame
MPG=1 TIME=0
