Old 04-08-2015, 09:55 AM   #282 (permalink)
vrmouseyd15b
ALL UP ON THE INTERWEB!!!
vrmouseyd15b's Avatar
skidmark - super snail - '89 honda civic wagon WAGOVAN
Team "Old SKOOL"
90 day: 30.87 mpg (US)
Pituca - '19 Honda Insight Touring
90 day: 39.34 mpg (US)
So, after changing the oil, I like to clean and tire shine things under the hood. Oven cleaner is a good thing...
Eats the grease right up, it's been a little while. While I was cleaning things, I found that one of the spade connectors for the reverse lights had come loose.
Then I found the broken wire at the cooling fan temp sensor plug:
You can't really see it, but the red wire was broken off, and right after taking the pic, the other wire let go! Found another plug in my "doodads pile" and soldered / heat shrunk it in place..
After finding the broken wires, I decided to peek around and make sure there weren't going to be any more surprises - THERE WERE!
I don't remember what this one is for, but the wire broke off the connector. Couldn't find another similar connector in my goodie bag, and the damn thing wouldn't take any solder. I ended up brazing the connector onto a bit of speaker wire and heat shrinking it as well:
Not sure what that one was called, but it goes here on the head..
good times! gotta love playing around with 25 year old wires..NOT! but I think Skiddy's ready for now. This has me thinking the OBD1 conversion will require a new harness rather than trying to re-use these old wires...
wiring checks out for now, time to connect things again and secure wires..
Dizzy back in place, starting to hide the speaker wire...
From this angle, you'd never know, but I already showed you - don't tell anybody!
So, Skiddy's got a fresh bit of wiring love under the hood, and fresh oil. good for another 2,000 miles or until I get bored....
Thanks,
Victor
